1996 Cadillac El Dorado Engine Idle
1996 CADILLAC ELDORADO
144,000 MILES • V8 • FWD • AUTOMATIC
RCMJ
My engine will idle higher than usual when in gear. When taken out of gear the idle will race to 3000 RPM. This is an intermittent problem, when have checked for Vacumn leaks disconnected the Cruisse control throttle cable and replace the IAC unit and the problem is still ongoing. Where should I look next?
Jun 25, 2010 at 5:19 AM
FACTORYJACK
  • 4,159 POSTS
Is the throttle cam at it's rest, or is the throttle stuck open. Another check would be the throttle position sensor.
Jun 25, 2010 at 2:44 PM
RCMJ
My last position was to replace the throttle position sensor and with everything else that was completed this seem to correct the problem. So far so good...Thanks, RC
Jul 6, 2010 at 4:31 AM
