1996 Cadillac El Dorado code P1380
105,000 MILES • V8 • FWD • AUTOMATIC
MELNIX
We have been getting code P1380 on our car. It runs rough fom time to time so I changed the plugs. Which helped for about 3 starts and stops then the code came back. I was told that the camshaft positioner sensor might be the problem. I can't locate the sensor. Can you tell me where to find it? Also could there be another problem causing this code?
Dec 10, 2008 at 6:35 AM
JAMES W.
  • 2,394 POSTS
The CPS is located on the front right side of the motor on the cylinder head. Hope this helps and thanks for your donation.
Dec 10, 2008 at 8:00 AM
