blower motor not working
SCOTTGUN
1995 Cadillac El Dorado V8
When I select AC, heat or defrost the fan won't start . I'm hoping it's just a fuse. Where are the fuses located
Aug 2, 2010 at 9:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
fuse blocks are located to left of the steering column under the dashboard, behind a carpeted cover on right side of the dash, behind a panel inside the glove box in the trunk compartment or under the hood. #4 fuse 40 amp
Cheers
Aug 2, 2010 at 3:04 PM
SCOTTGUN
That did the trick thanks guys!
Aug 2, 2010 at 3:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Aug 2, 2010 at 3:54 PM
GEORGEBOB
Heater problem
1994 Cadillac El Dorado V8 Front Wheel Drive Automatic 43,000 miles
the blower is not working i tried another blower no good the repair manual I have says ther is a resistor pack that could be the problem . where is it located?
Jan 30, 2018 at 2:32 AM (Merged)
  • 110,248 POSTS
Hi:
According to our Mitchell manual, it's located in the wiring harness near the blower motor.
09JOTAYLOR
Heater problem
1992 Cadillac El Dorado V8 Front Wheel Drive Automatic 164230 miles
my front blower quit working yesterday but thre rear still works i wouldn't mind using just the rear except from where the defroster is needed and it would be nice to have heat in the front i can do the repair my self but i don't know where to start i can't seem to find the actual blower/blower motor. and how do i remove it any help would be greatly appreciated.
FACTORYJACK
  • 4,159 POSTS
The blower is out under the hood in the approximate center of the firewall, A black barrel shape about the size of a soup can, two wires going to it. You can determine if power and ground is at the motor by placing a test light across the two wires, and turning the system on. If it lights, you need a blower motor. Try tapping on this barrel(motor), and see if it tries to run. Sometimes dirty, worn, or sticking brushes can free, and provide an indication that you are on the right path. If it needs to be replaced, the best method is to remove the front two subrame bolts and lower the front of the engine.
BIGMIKEK
1998 Cadillac El Dorado V8 Front Wheel Drive Automatic
I have a 1998 cadillac eldorado, the ac works fine, but the fan inside doesn't work most of the time. It will work here and there, but mostly doesn't work. I can feel cold air barely trickling out of the vents, but only when I'm moving. Do you think my blower motor is bad?
BLUELIGHTNIN6
  • 16,542 POSTS
with an intermittent failure like that it is hard to diagnose, most likely it is the blower motor failing but best thing to do is wait and see if it gets worse. it could be wiring damaged as well so wiring at the control panel and the blower motor will need inspected
