1995 Cadillac El Dorado compression
35,000 MILES • V8 • FWD • AUTOMATIC
SCOTTGUN
My car is hesistating severely while attempting to accelerate on the highway. Is it clogged injectors ? If so how do I clean them. I recently had the plugs and wires replaced.
Sep 24, 2010 at 1:34 AM
  • 75,988 POSTS
Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sep 24, 2010 at 1:41 AM
