[quote:a07b7db3d7="bigeric"][quote:a07b7db3d7="Buzzsaw"][quote:a07b7db3d7="bigeric"]ok these is waht it gave me
P032
P109
I052
A011CURENTLY
NO SIR
T083
S036
S037
S038
S043
S044
S050
PCM?
THATS THE ORDER THEY WERE GIVIN IN
thankyou very much[/quote:a07b7db3d7]
you need to find out what the P codes are, there your PCM codes, my book doesnt go back that far and they dont look fimilar
the SO codes are suspension codes, you need a relay put in for the RSS module or a wire cut on it, is the repair
AO11 is AC I believe[/quote:a07b7db3d7]
ok this is what i have found on the codes i hope its accurate
P032 (E032) ................................................. Open MAP Sensor Signal
P109 (E109) ....... Keep Alive Memory (KAM) Reset/PCM has lost primary battery power
I052 ....................................................... Keep Alive Memory Error
A011 .......................................... High Side Temperature Sensor Circuit
T083 ......................................................... Brake Fluid Level LowSIR Codes
where would the rss module be located on the car
thanks alot man[/quote:a07b7db3d7]
ok, the map sensor is on the top of the throttle plates, its a little black rectaingle about an 1 1/2 long, easy to get to and cheap, the p109 and IO 52 is you disconnected the battery, also the IO 52 could be a relay thats under the hood, does your raido turn off when you open the door? ( ck: get in car close the doors and start car, turn on radio, turn off car pull out the key and radio should stay on, open door and radio should shut off, relay is good if this happends )
as far as the AO 11 does or did your AC work?
the RSS module is either under the drivers seat, ( you cut a wire ) or in the trunk behind the back seat, there is a panel back there thats velcroed on just pull it down, ( a relay is needed for that repair ) there is also a fuse box back there ck thoes fuses
Apr 10, 2008 at 10:53 PM
