1994 Cadillac EL Dorado TURNS BUT WONTS START
BIGERIC
  • 1994 CADILLAC ELDORADO
  • V8
  • FWD
  • 150,000 MILES
I have a 94 elldorado 4.6 lit the car wont start up it spins ignition module was testen and its fine fuses are fine everything check is fine but it wont start I do not have spark I have replaced the ignition module adn its the same problem but no spark some times if you go out it will start but for the most part it will not any ideas that might help thankyou
Wednesday, March 26th, 2008 AT 3:44 PM
Test the coil packs and crankshaft position sensor
Wednesday, March 26th, 2008 AT 3:54 PM
BUZZSAW
  • 1,198 POSTS
Scan the codes, off and warmer on the heater controls, with the key in the on position, dont replace anything else till you scan the codes
its could be your cam sensor or crank sensors for spark
did you try carb cleaner down the throttle plates for fuel?
Wednesday, March 26th, 2008 AT 7:19 PM
BIGERIC
  • 5 POSTS
Where is the cam sensor and the crank sensor located at and is there a way to test them or do I just replece them thanks
Thursday, March 27th, 2008 AT 10:09 AM
BUZZSAW
  • 1,198 POSTS
Scan the codes, I showed you how
Thursday, March 27th, 2008 AT 1:19 PM
BIGERIC
  • 5 POSTS
I have done that and im not getting a code do I just hold the button till it show the code or could you be little more specific I tried doing it but im not getting anything maybe im doing something wrong
thank you
Thursday, March 27th, 2008 AT 2:16 PM
BUZZSAW
  • 1,198 POSTS
Hold down off and warmer at the same time, with the key in the on position
Friday, March 28th, 2008 AT 1:24 AM
BIGERIC
  • 5 POSTS
Ok these is waht it gave me
P032
P109
I052
A011CURENTLY
NO SIR
T083
S036
S037
S038
S043
S044
S050
PCM?
THATS THE ORDER THEY WERE GIVIN IN
thankyou very much
Friday, March 28th, 2008 AT 11:34 AM
BUZZSAW
  • 1,198 POSTS
You need to find out what the P codes are, there your PCM codes, my book doesnt go back that far and they dont look fimilar
the SO codes are suspension codes, you need a relay put in for the RSS module or a wire cut on it, is the repair
AO11 is AC I believe
Friday, April 4th, 2008 AT 3:03 AM
BIGERIC
  • 5 POSTS
AO11 is AC I believe[/quote:6ed66983e9]
ok this is what I have found on the codes I hope its accurate
P032 (E032). Open MAP Sensor Signal
P109 (E109). Keep Alive Memory (KAM) Reset/PCM has lost primary battery power
I052. Keep Alive Memory Error
A011. High Side Temperature Sensor Circuit
T083. Brake Fluid Level LowSIR Codes
where would the rss module be located on the car
thanks alot man
Tuesday, April 8th, 2008 AT 8:37 AM
BUZZSAW
  • 1,198 POSTS
AO11 is AC I believe[/quote:a07b7db3d7]
thanks alot man[/quote:a07b7db3d7]
ok, the map sensor is on the top of the throttle plates, its a little black rectaingle about an 1 1/2 long, easy to get to and cheap, the p109 and IO 52 is you disconnected the battery, also the IO 52 could be a relay thats under the hood, does your raido turn off when you open the door? ( Ck: get in car close the doors and start car, turn on radio, turn off car pull out the key and radio should stay on, open door and radio should shut off, relay is good if this happends )
as far as the AO 11 does or did your AC work?
The RSS module is either under the drivers seat, ( you cut a wire ) or in the trunk behind the back seat, there is a panel back there thats velcroed on just pull it down, ( a relay is needed for that repair ) there is also a fuse box back there ck thoes fuses
Friday, April 11th, 2008 AT 5:53 AM
