1994 Cadillac El Dorado sputters and cut off and wont start
75,000 MILES • V8 • FWD • AUTOMATIC
94ELDOG
well today i was driving down the street and my car has been running good with no signs of problems til then my car sputtered and then it idled very ugly below 1000 rpm i tryed giving it gas but didnt help now it wont even start
i can hear the fuel pump but i dont know
any suggestions
Mar 22, 2008 at 2:31 PM
BUZZSAW
  • 1,198 POSTS
[quote:0090cab835="94eldog"]Engine Mechanical problem
1994 Cadillac El Dorado V8 Front Wheel Drive Automatic 75000 miles
any suggestions[/quote:0090cab835]
squirt carb cleaner in the throttle housing, if it starts its fuel if not its spark
Mar 24, 2008 at 4:40 AM
94ELDOG
hey thanks for advice first i changed the fuel filter and it was horrible it was dirty as it can be and i blew in the filter and brown gas poured out well i put a new one in and then i squirted the carb cleaner in the housing and it cranked but it seem to just burn the carb cleaner then it would cut back off i did this many times and same thing it seems like its gettin no gas do you think the fueul pump shpuld be changed cause the filter was bad .....opr what do you suggest???????
Mar 25, 2008 at 9:41 AM
BUZZSAW
  • 1,198 POSTS
[quote:4df882eb3a="94eldog"]hey thanks for advice first i changed the fuel filter and it was horrible it was dirty as it can be and i blew in the filter and brown gas poured out well i put a new one in and then i squirted the carb cleaner in the housing and it cranked but it seem to just burn the carb cleaner then it would cut back off i did this many times and same thing it seems like its gettin no gas do you think the fueul pump shpuld be changed cause the filter was bad .....opr what do you suggest???????[/quote:4df882eb3a]
yes the pump, sorry to say its around 600.00 bucks, and the tank has to come down
2.5 hrs labor + pump at the dealer
Mar 26, 2008 at 12:25 PM
