Tuesday, May 20th, 2008 AT 4:41 AM
I have replaced the thermostat, water pump, flushed the radiator and replaced with the required Antifreeze. But it is still overheating, would the cooling fans not running cause the engine to overheat?If not what is causing the motor to overheat?
