1994 Cadillac El Dorado CRANKSHAFT SENSOR
1994 CADILLAC ELDORADO
LTKCM
  • 5 POSTS
Engine Mechanical problem
1994 Cadillac El Dorado V8 Front Wheel Drive Automatic
I recently replaced both crank sensors. With both of them plugged in the car only runs on 4 cylinders. However if you unplug 1 it doesn't matter which one, it runs fine. However, it is hard to start. Can you tell me what to do next?
May 31, 2008 at 6:58 AM
BUZZSAW
  • 1,198 POSTS
[quote:f0a50f53f6="LTKCM"]Engine Mechanical problem
I recently replaced both crank sensors. With both of them plugged in the car only runs on 4 cylinders. However if you unplug 1 it doesn't matter which one, it runs fine. However, it is hard to start. Can you tell me what to do next?[/quote:f0a50f53f6]
do you have a ck engine light on? scan the codes anyway, off and warmer on the heater controls at the same time, with the key in the on position
May 31, 2008 at 7:27 PM
LTKCM
  • 5 POSTS
I did check the codes, they are as follows: PO83, PO93.
May 31, 2008 at 11:11 PM
LTKCM
  • 5 POSTS
[quote:5d39c72136="LTKCM"]I did check the codes, they are as follows: PO83, PO93.[/quote:5d39c72136]
Jun 7, 2008 at 8:52 PM
BUZZSAW
  • 1,198 POSTS
[quote:f7b3402392="LTKCM"][quote:f7b3402392="LTKCM"]I did check the codes, they are as follows: PO83, PO93.[/quote:f7b3402392][/quote:f7b3402392]
PO 093 is your evap sys, gas tank pressure leak
PO083 is intake valve control solenoid bank 2
Jun 8, 2008 at 8:43 PM
