1994 Cadillac El Dorado car wont start
HYPR2JILLO
1994 Cadillac El Dorado V8
my cadillac just wont start
Aug 19, 2010 at 12:36 PM
  • 75,988 POSTS
Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 19, 2010 at 1:00 PM
