1994 Cadillac El Dorado cadilllac wont start
HYPR2JILLO
I drove my cadilllac home from work ,had no problems, went to start in back up and nothing happend! no cranking just a light click when you turn the key,also replaced the battery, pllease help!
Aug 22, 2010 at 10:58 AM
  • 75,988 POSTS
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Aug 22, 2010 at 11:45 AM
