1994 Cadillac El Dorado BRAKE BOOSTER VACUUM SENSOR
LTKCM
  • 5 POSTS
Engine Mechanical problem
1994 Cadillac El Dorado V8 Front Wheel Drive Automatic
My car's computer is coming up with a code which is saying it's an open brake booster vacuum sensor. Where is this located. Also, I am getting 2 other codes one is PCM memory reset, and distributor signal interupted. The car is idling rough and won't stay running. Any ideas on what the problem is? We just replaced the crank sensor and now these 3 codes are coming up.
May 6, 2008 at 7:47 AM
BUZZSAW
  • 1,198 POSTS
[quote:a1f45ce614="LTKCM"]Engine Mechanical problem
My car's computer is coming up with a code which is saying it's an open brake booster vacuum sensor. Where is this located. Also, I am getting 2 other codes one is PCM memory reset, and distributor signal interupted. The car is idling rough and won't stay running. Any ideas on what the problem is? We just replaced the crank sensor and now these 3 codes are coming up.[/quote:a1f45ce614]
memory reset is you disconnected the battery. but I need the code #
push off and warmer on the heater controls at the same time with the key in the on position, look in the message center for the codes
did you do a crankshaft relearn after the replacement of the crank sensors?
May 13, 2008 at 4:16 AM
LTKCM
  • 5 POSTS
What do you mean by "relearn" the crank sensor, and how do you do this?
May 16, 2008 at 12:56 AM
BUZZSAW
  • 1,198 POSTS
[quote:b7090a583f="LTKCM"]What do you mean by "relearn" the crank sensor, and how do you do this?[/quote:b7090a583f]
please scan your codes, the way I had asked you to so we can see the codes your have, in order to help you. do this through your heater controls
after crankshaft sensors are replaced they need to have a relearn done at the dealer through the tech 2( which is a diagnostic tool for GM modles and other things )
May 16, 2008 at 1:53 AM
