1993 Cadillac El Dorado Water pump/thermastat
75,000 MILES • V8 • FWD • AUTOMATIC
RANDYBEAR
My question is what should the coolant temp.read on the onboard computer at normal running conditions. Trying to determine whether i have a bad water pump or themastat. It was steaming out the over flow line, so when it cooled down i refilled it with 50/50 coolant.
Thanks,
Randy
Jan 18, 2008 at 11:13 AM
BUZZSAW
  • 1,198 POSTS
[quote:091d7f1328="Randybear"]Engine problem
1993 Cadillac El Dorado V8 Front Wheel Drive Automatic 75000 miles
Thanks,
Randy[/quote:091d7f1328]
if no leaks are found replace the thermostat first, sometimes this motor is hard to get the air out of the cooling sys (190 to 215 is normal)
Jan 18, 2008 at 2:56 PM
