1993 Cadillac El Dorado Low oil pressure warning
176,000 MILES • V8 • FWD • AUTOMATIC
BODADDYBO
My Eldorado has been showing a warning on the display
"Low oil pressure turn off engine" I am at 40% on the oil life index, have checked compression/leak down/ all good. Motor runs good and strong and has been well maintained. Question? Am I looking at a sensor problem or a worn oil pump/relief valve issue. I understand that there is an oil pressure sensor and an oil level sensor. Not wanting to replace parts without knowing cause
When warning displays I immediately turn engine off. Also do not hear any knocking / pinging etc engine always sounds good
Mar 19, 2008 at 3:14 AM
BUZZSAW
  • 1,198 POSTS
[quote:cc63ece0a3="BODADDYBO"]Engine Mechanical problem
1993 Cadillac El Dorado V8 Front Wheel Drive Automatic 176000 miles
When warning displays I immediately turn engine off. Also do not hear any knocking / pinging etc engine always sounds good[/quote:cc63ece0a3]
have you ever had the intake gasket replaced? look for coolant in the oil, oil will look milky,
if it is leaking, you will need a new motor or a remanufactured one, do not try to fix it you will be wasting your money
Mar 20, 2008 at 12:57 AM
BODADDYBO
[quote:5d6e99770d="Buzzsaw"][quote:5d6e99770d="BODADDYBO"]Engine Mechanical problem
When warning displays I immediately turn engine off. Also do not hear any knocking / pinging etc engine always sounds good[/quote:5d6e99770d]
if it is leaking, you will need a new motor or a remanufactured one, do not try to fix it you will be wasting your money[/quote:5d6e99770d]
Mar 20, 2008 at 1:33 AM
