1993 Cadillac El Dorado leak
140,000 MILES • V8 • 2WD • AUTOMATIC
JEAN LAVA
I have a coolant leak, passenger side. Replaced water pump, hoses are OK, leak is steady running onto chassis close to wheel. After car uns, can hear a small hissing near alternator, water sprays off of belt to hit bottom of radiator
May 5, 2008 at 10:08 PM
  • 31,937 POSTS
Hi there,
you should get the system pressure tested, check around the area you feel is the problem , use a torch and a mirror to look in hard to see places, you should be able to locate you leak easily.
Mark (mhpautos)
May 5, 2008 at 10:14 PM
