1993 Cadillac El Dorado Check Transmission Fluid light
1993 CADILLAC ELDORADO
14,000 MILES • V8 • 2WD • AUTOMATIC
SKAGIT4
The fluid is fine, how do I reset the warning message on the dash?
Oct 22, 2009 at 5:36 PM
FACTORYJACK
  • 4,159 POSTS
I'm certain that it can be done with a scan tool. It might also be possible to do it through on-board functions however, I don't have any info hear at home. I will try to research it tomorrow, and reply with result.
Oct 26, 2009 at 3:39 PM
FACTORYJACK
  • 4,159 POSTS
You can reset the trans oil life through the on-boards. Just to make sure, it is not a 'Service Transmission' message your getting on the info center, is it?
Oct 31, 2009 at 3:28 AM
SKAGIT4
It just says check transmission fluid.
Oct 31, 2009 at 4:05 AM
