1992 Cadillac El Dorado Theft System
GUTOWSKIS
1992 Cadillac El Dorado Automatic 124000 miles
When I try to start up the car it says starting monitor disable system due to theft system. What can I do myself so I don't have to take it to the dealership?
Oct 11, 2010 at 11:06 AM
FACTORYJACK
  • 4,159 POSTS
At the base of the column, there is a large connector. Coming out of the column is a couple small white wires in an orange conduit. With the key in the ignition, and the connector disconnected, check the resistance of the white wires. There should be something there at all key positions, other than open circuit. Ideally, it will be the same resistance as the key pellet. If it is open at any time, you have a failed ignition lock cylinder. You can either bridge the connector with a resistor pack of the key value, or replace the lock cylinder and keys. You will need keys if you replace the lock cylinder, because it cannot be coded. The thing to remember, is there are 15 possibilities of key value, so yours needs to be determined at an exact replacement obtained. A dealer can interrogate the key, or a locksmith. Someone with some experience in the system might be able to relate a resistance value to the correct VATS key code as well.
Oct 11, 2010 at 4:08 PM
