1992 Cadillac El Dorado The dash board cluster
1992 CADILLAC ELDORADO
106,000 MILES • V8 • 2WD • AUTOMATIC
JACUZZI45
The dash board cluster flat lines (all read outs) and a check engine message appears. Then the heat maxes out at 90 degrees and the blower turns on. It stays this way for a minumum of 10 minutes. Restarting the engine doesnt make a difference. I have replaced the cluster three times. Please tell me how to stop this.
Sep 18, 2010 at 12:03 PM
ERNEST CLARK
  • 1,730 POSTS
This is most likely a short in the wiring, though you could have a bad contact or cut wire that's giving a very high resistance in the circuit.
If you're handy with a multi-meter, you can track it down. If not, you'll have to take it in.
If you want to try tackling this project yourself, write back in and I'll try hunting down a wiring diagram. But I can't promise you that I can.
You could also buy a repair manual from AutoZone or Napa. These will have a wiring diagram, but I'm not sure if it'll supply the values for the circuits.
Sep 21, 2010 at 11:09 PM
CADIEMAN
  • 3,544 POSTS
usally u need a center dash info center we enjoy your feedback
Sep 23, 2010 at 8:54 AM
