1991 Cadillac El Dorado flasher
KESIBLEY
Electrical problem
1991 Cadillac El Dorado V8 Front Wheel Drive Automatic
where is the flasher located on this car? what does it look like? is it a module or a regular flasher?
Mar 6, 2009 at 6:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Both the hazard as well as the turn signal flasher are regular flashers. Should be round in shape and usually a silver color. Pull out straight like a fuse to remove and replace.
Turn signal flasher is located in the front seating area, driver side, under dash, mounted on passenger side of steering column.
Hazard flasher is located front seating area, driver side, under dash, mounted above steering column.
Thanks for using 2CarPros.com!
Mar 6, 2009 at 6:21 AM
