1989 Cadillac El Dorado my car keeps showing cooling fan fa
JUAN00MARTINEZ
Engine Cooling problem
1989 Cadillac El Dorado V8 Two Wheel Drive Automatic
i change a hose but it keeps showing cooling fan fault and after a while it start showing coolant and tempeture sign and the engine start to heat up how do i fix it
Aug 17, 2010 at 8:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
is the radiator fan(s) coming on? if not check fuses and relays. if all OK then check engine coolant temp. sensor/switch
Aug 17, 2010 at 4:17 PM
