1988 Cadillac El Dorado start-up fuel problem
100,000 MILES • V8 • FWD • AUTOMATIC
WABASH_ELVIS
on start-up there should be a 1 or 2 second squirt of fuel into the carb. but i'm not getting it.....the car will start with starting fluid and run normal, until it is time to restart. since it runs normal, i assume that the fuel pump and filter is fine...I've check "all" the relays and fuses all seem fine......any sugestions?
Sep 23, 2008 at 9:49 AM
  • 75,988 POSTS
Get it to start while idling find the fuel pump relay remove it-did it died out?
Sep 23, 2008 at 10:12 AM
