Electrical problem
1988 Cadillac El Dorado 6 cyl Front Wheel Drive Automatic
THIS WAS WHAT WAS PERFORMED ON CAR ALREADY
DIAGNOSTIC CHECK: CHECK ENGINE LIGHT. INSPECT, PERFORM TESTING,AND OR RUN COMPUTOR ANALYSIS FOR TROUBLE SHOOTING ON VEHICLE. CHECKED VEHICLE OUT FOR SERVICE SYSTEM ON DASH. TEST FAULT CODES CALLED TO REPLACE THE BCM AND ECM COMPUTORS ACCORDING TO FAULT CODES.THIS DID NOT REPAIR ISSUE SO COMPUTORS WERE REMOVED AND SENT BACK.
SERVICE SYSTEM ERROR COMES ON WHEN CAR IS STARTED. RESET AND WHILE DRIVING AT SOME PERIOD ERROR COMES ON AGAIN OR THE CHECK ENGINE LIGHT COMES ON. SOMETIMES CHECK ENGINE LIGHT WONT GO OFF.
Apr 16, 2009 at 1:34 AM
