1985 Cadillac El Dorado Won't start/Fuel pressure problem.
JOE DD
  • 14 POSTS
Engine Performance problem
1985 Cadillac El Dorado V8 Front Wheel Drive Automatic
I have a 1985 Cadillac Eldorado that wont start unless i spray starting fluid into the Throttle body.
I rented a fuel pressure gauge and it showed no pressure at all on the fitting at the line at the TBI.
When i turn on the key,fuel pump does run for a couple secs.Disconnected the fuel filter and checked pressure there as well,none.i cranked it with the line removed at the filter and fuel does pump out but not like i think it should,not very forceful.
Would this be a weak pump or a faulty pressure regulator.i have heard that these are known for ruptured diaphrams in the regulators.Help,i dont want to drop the tank and put in a pump only to find out im wrong..dont have the money to waste.Any advise would be welcome.
TIA
Oct 27, 2010 at 8:36 AM
  • 75,988 POSTS
To rule out the fuel pump you must check the fuel pressure if its within specs
Oct 27, 2010 at 10:06 PM
JOE DD
  • 14 POSTS
I DID check fuel pressure both at the fitting at the throttle body and before the filter,both show no pressure at all.NONE....
But with the car jacked up and the fuel line off before the filter or even after the filter ,fuel does pump out,albeit not real forceful...not sure if its just because the car is jacked up or what...pump does run, but fuel isnt really coming out forceful at all....if i disconnect line at TBI and crank it,no fuel reaches there at all.I'msuming its a weak pump but not sure if it can be the pressure regulator .
Any additional advise would be appreciated.
TIA
Oct 29, 2010 at 6:34 AM
  • 75,988 POSTS
Sounds like the fuel pump is gone
Oct 29, 2010 at 6:36 AM
JOE DD
  • 14 POSTS
Thats what i thought ,just needed it confirmed.
Any chance a regulator with a blown diaphragm causing this?A buddy suggested this,thats why i havent dropped the tank yet.
Thanks again for your assistance.
Oct 29, 2010 at 6:40 AM
  • 75,988 POSTS
You checked it before the fuel filter the regulator is out of the picture and there's no pressure points to the fuel pump
Oct 29, 2010 at 6:42 AM
JOE DD
  • 14 POSTS
OK,That Makes sense.
I going to install the fuel pump this weekend.
Thanks for your help.
I'll let you know the outcome.
Thanks again
Oct 29, 2010 at 6:49 AM
JOE DD
  • 14 POSTS
Hi
Just a follow up...
Dropped the tank and found the rubber hose connection from the pump to the sender was ruptured
Replaced the pump and the hose
Thanks again for your help
Nov 5, 2010 at 7:18 AM
  • 75,988 POSTS
You're welcome and TY for using 2carpros-Good Luck
Nov 5, 2010 at 8:38 AM
