1984 Cadillac El Dorado
DAISY DELUCA
Electrical problem
1984 Cadillac El Dorado V8 Front Wheel Drive Automatic
My starter went on when I turned the key but the engine did not. The engine did not want to turn off after putting the ignition key in the off position. The car finally went off burning the starter. What could be the problem
Sep 2, 2010 at 8:37 AM
  • 75,988 POSTS
You sure the engine is not seizing up/locked-up? Check it by manually turning the crankshaft over 720degs
Sep 2, 2010 at 9:11 AM
