1978 Cadillac El Dorado Car nose-dives to the right when br
1978 CADILLAC ELDORADO
36,000 MILES • V8 • FWD • AUTOMATIC
CARPCAGE
The car nose-dives to the right when braking, especially at highway speed. Howevr, after braking several times in a row, the nose-diving decreases. After diving several miles without braking, it returns.There is also a clicking sound when driving at lower speeds. Clicking changes with speed and disappears when you brake. Can't tell if the clicking is from the front or back. At very low speed (less than 5mph) there is a slight ginding noise as if a brake pad is contacting a high point on a rotor and car learches very slightly. I suspect a stuck brake caliper. Your opinion is appreciated.
Oct 1, 2010 at 6:39 AM
MMPRINCE4000
  • 8,548 POSTS
You could have a caliper problem, but nose dive is most likely a shock/spring.
Oct 13, 2010 at 2:29 AM
