How do I release or retract the rear calipers for brake pad replacement?
Feb 7, 2010 at 4:16 AM
FACTORYJACK
✓Experienced Mechanic
Since the park brake is internal to the caliper, the piston needs to be turned in.It is normal clockwise rotation to screw piston inward, and you need to apply pressure as well. this video will show you how.
