right rear window wont go up or down. I hear a click when button is depressed to activate
Oct 22, 2010 at 8:57 AM
SATURNTECH9
✓Experienced Mechanic
If you hear the click coming from the door then you most likely have a bad window motor.You will need to remove the door panel and see if you have power and ground to the window motor.
