2003 Cadillac DTS window
2003 CADILLAC DEVILLE DTS
60,000 MILES • V8 • FWD • AUTOMATIC
REGEBREN
right rear window wont go up or down. I hear a click when button is depressed to activate
Oct 22, 2010 at 3:57 PM
SATURNTECH9
  • 30,869 POSTS
If you hear the click coming from the door then you most likely have a bad window motor.You will need to remove the door panel and see if you have power and ground to the window motor.
Oct 22, 2010 at 4:04 PM
