2003 Cadillac DTS Door Panel
CADDYDTS03
Interior problem
2003 Cadillac DTS V8 Front Wheel Drive Automatic
How do you remove the front driver side door panel on a 2003 Cadillac DTS?
Jul 30, 2009 at 8:27 AM
FACTORYJACK
  • 4,159 POSTS
Remove the plate behind the inside door handle, and the screw. remove the manual lock knob by prying out the little plastic square. Pry around the outside edges af the panel to release the clips, grab the pull handle and lift.
Jul 30, 2009 at 2:48 PM
