2003 Cadillac DTS airbag dtc
137,000 MILES • V8 • FWD • AUTOMATIC
O10WEN
I have snap on M2500
codes B0041 driversidedeploymentloop open
B0065 driversidepretensioner deployment resisistance high
cleared them B0041 came back
Nov 8, 2009 at 5:36 AM
FACTORYJACK
  • 4,159 POSTS
Check the connections under the seat, the yellow connectors. You could possibly have some wires damaged under the seat, without having a load tool to substitute in place of the side inflator, you can't really say the inflator is faulty. I am not 100% certain, but you may be able to swap side inflators from side to side for diagnostic purposes, I think the connectors are the same. To get the inflators out, you need to remove the rear map pockets from the seats, and remove the 10mm fasteners that secure them.
Nov 10, 2009 at 2:15 PM
