2003 Cadillac DTS air bag system
137,000 MILES • V8 • FWD • AUTOMATIC
O10WEN
car had ck engine light
B0041 Drivers side deploymentloop open
B0065driver side Pretensionerdeployment resistance High
Nov 8, 2009 at 10:13 AM
BMRFIXIT
  • 19,053 POSTS
on the B0041 I would suspect clock spring as its code for an open circuit for the driver air bag module and most common area for the short is in the clock spring
and code B0065 I would check and suspect driver side set belt buckle and its wiring
use the scanner and clear codes
Nov 9, 2009 at 10:49 AM
