2002 Cadillac DTS Battery
CANTHONY1273
2002 Cadillac DTS V8 Front Wheel Drive 50000 miles
Where is the battery located at in the 2002 dts?
Jan 23, 2009 at 12:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try under the back seat . Pull the seat portion up and out toward the front seat. There are two litte black flat points, about three inches wide, that slip behind the back part of the rear seat backs. The battery is large and heavy so you may have to take the seat completely out to get to the battery. If you have heated rear seats there is a small connection you may need to disconnect to free up the seat for removal.
Thanks for using 2CarPros.com !
Jan 23, 2009 at 12:49 PM
