2002 Cadillac DTS Air Conditioner
2002 CADILLAC DEVILLE DTS
98,000 MILES • V8 • 2WD • AUTOMATIC
BIRDIEBLASTER
When Driving with the Air conditioner on(AUTO STTING),Sometimes it Just stops,Nothing like it was shut off no fan no nothing ,then about 1 to 3 min later it will come back on and work perfectly for a few days then do it again,Its starting to happen more frequently lately about once a day .
Aug 16, 2009 at 2:55 AM
FACTORYJACK
  • 4,159 POSTS
Does the screen black out or do anything, or does the blower just stop working.
Aug 17, 2009 at 4:48 PM
BIRDIEBLASTER
Screen does not black out Still Shows On and Fan on Auto Everything Quits working No Air, No Blower, No Fan, Nothing Then after a few Min it comes back on Normal as it was
Aug 18, 2009 at 10:07 AM
FACTORYJACK
  • 4,159 POSTS
Sounds like you just may have a blower concern. If you remove the sound insulator from the lower right instrument panel(below the glove box/black) to where you can access the blower motor. When it quits either check that you have power and ground at the time with a test light or meter or, rap on the motor and see if it coincidentally resumes operation.
Aug 18, 2009 at 3:27 PM
BIRDIEBLASTER
Thanks I will try that,But usuallly I am out Driving when it happens and it returns to Ok before I get back home ??
Aug 19, 2009 at 1:53 AM
FACTORYJACK
  • 4,159 POSTS
If you can, leave the insulator off for easy access, and pull over to check it, or if you have a second person.
Aug 19, 2009 at 5:40 PM
