2001 Cadillac DTS WIERD
104,000 MILES • V8 • FWD • AUTOMATIC
JRIGGINS
THE CARS FUEL PUMPS STAYS RUNNING WHEN CAR IS OFF AND KEY IS OUT?
THE CAR WILL NOT START, NO SOUNDS AT ALL WHEN KEY IS TURNED?
WHEN KEY IS TURNED THE HEADLIGHTS FLASH RAPIDLY NON-STOP TIL' BATTERY IS DISCONNECTED AND THE KEY IS LOCKED IN IGNITION UNTIL BATTERY IS RE-CONNECTED?
NEW BATTERY WAS INSTALLED TODAY AND DID NOT REMEDY SITUATION
Nov 6, 2010 at 5:21 PM
KHLOW2008
  • 41,812 POSTS
Unplug the fuel pump relay and test for battery voltage at terminal # 86. There should be none when ignition is off. If battery voltage is not available, replace the relay and retest if fuel pump works with ignition off.
The headlight flashing indicates the security systm is armed and you need to disarm to be able to start.
DISARMING AN ARMED SYSTEM/SILENCING AN ALARM
NOTE:
Using power door unlock switch or manually unlocking doors does not disable Content Theft Deterrent (CTD) arm mode. Disconnecting battery or pulling fuses does not disable arm mode, since remote function actuator module stores CTD mode status in memory.
• To disarm CTD system when in standby mode, SECURITY indicator on or flashing, and door(s) open:
• Press either power door unlock switch.
• Use key to unlock front door.
• Press unlock button on remote transmitter.
• Insert a valid Pass Key III key into ignition switch and turn to RUN position.
• To disarm CTD system when in armed mode:
• To disarm CTD system when activated (alarming mode).
© 2008 Mitchell Repair Information Co., LLC.
When starter is not able to be cranked after disarming, check the gear shift position. Try shifting to neutral and test if it could be started.
Nov 6, 2010 at 9:37 PM
