2001 Cadillac DTS STARTING
59,500 MILES • V8 • FWD • AUTOMATIC
SHIRLEY S
hAVE NEW BATTERY.EVERY MONTH OR SO CAR WONT START.AFTER AN HOUR OR IT STARTS. there is no noise at all when it doesnt start.feels like turning key against air.Thoughts? PLEASE
Aug 27, 2009 at 2:59 AM
SHIRLEY S
2001 caddy dhs with 59,500 miles. new battery inslled 3 weeks ago. every month or car wont turn over.key fells like going against nothing. after an hour or so it starts with no problem and is fine for a month or so. any thoughts? PLEASE!
Aug 27, 2009 at 3:10 AM
MERLIN2021
  • 17,250 POSTS
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Aug 28, 2009 at 7:55 AM
FACTORYJACK
  • 4,159 POSTS
To get a better understanding, when you say "feels like it's going against nothing", does it sound like the starter is not engaging the flexplate, or the engine is turning over with no compression? Do you try this one time and wait an hour, or several times and then wait an hour. The aforementioned pass lock relearn would not be intermittent in nature. I would first start with checking to see if the starter is getting a signal when this is happening. If you can provide a bit more info on the symptom. I have, in the past, had a sticking oil pressure regulator that causes max oil pressure and creates a no compression-no start, have also had starters that spin but don't engage the flexplate.
Aug 28, 2009 at 3:30 PM
MERLIN2021
  • 17,250 POSTS
I dont know about the passlock not being intermittent, I work with some one who's chevy was intermittent.
Aug 28, 2009 at 11:14 PM
FACTORYJACK
  • 4,159 POSTS
A pass-lock fault could be intermittent. A re-learn would most likely not correct a pass-lock fault.
Aug 29, 2009 at 3:51 AM
MERLIN2021
  • 17,250 POSTS
That may be true, they ended up cutting a yellow wire to the system.
Aug 30, 2009 at 12:16 AM
