Hi, concerning the ERg valve pintle; when you rattle the part should it make excesive noise as if somthing is loose inside. Also, should the pintle open and close under the force of shaking?? Also, should you be able to push down the pintle under the pressre of a toothpick???
Car has loud knock when gas is used only. No acceleration, no noise.
Thanks,
Thanks,
Apr 17, 2009 at 1:54 AM
