2001 Cadillac DTS coolant loss overheating
100,000 MILES • V8 • FWD • AUTOMATIC
ANDREASTSAVALOS
wer the water desapear no lleakage
Dec 19, 2009 at 12:56 PM
PEAR69
  • 1,482 POSTS
You could have an internal leak in the radiator causing coolant to contaminate the engine oil or transmission fluid- or- the lower intake gaskets could be leaking coolant into the engine internally..Either way, this leak must be found asap! I suggest that you do not run the engine until you find this leak or determine the cause of coolant loss..
Dec 19, 2009 at 3:33 PM
