2001 Cadillac DTS Car stutters & cuts off when sitting
WD1598
2001 Cadillac DTS V8 All Wheel Drive 192K miles
2001 Cadillac DTS Deville keeps shutting off whenever I come to a stop. I have to keep starting the car and racing engine until I can finally get it into gear to move.
Aug 29, 2009 at 12:54 AM
FACTORYJACK
  • 4,159 POSTS
Make sure that all air snorkels after the mass airflow sensor are correctly installed and tight. Clean the throttle plate and idle air control valve passages. Is there a check engine light associated with this?
Aug 29, 2009 at 3:56 AM
LAMONT1970
i have the same problem. no check engine alert with this.
Jan 18, 2010 at 7:41 AM
