2000 Cadillac DTS thermostat
2000 CADILLAC DEVILLE DTS
150,000 MILES • V8 • FWD • AUTOMATIC
RAFAEL FARIAS
if my thermostat does not work, will it work if i cancel it or do i necesary need to replace it, OTHER THAN THAT WHAT ELSE CAN BE THE PROBLEM FOR OVERHEATING, THANK YOU..
Sep 3, 2009 at 6:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if it is faulty then it needs replaced. overheating can be caused by many things i.e. cooling fan(s) not operating, water pump faulty, coolant leaking, radiator clogged etc...
Sep 3, 2009 at 3:08 PM
