OIL PRESSURE SWITCH IS LEAKING AND WHEN I CRANK UP MY CAR IN THE MORNING THE ENGINE IS KNOCKING THEN IT STOPS AFTER 5 MINUTES. WHATS THE PROBLEM
May 9, 2010 at 12:24 PM
BLUELIGHTNIN6
✓Experienced Mechanic
have you replaced the oil switch already ? leaky oil switch can cause oil pressure to leak resulting in the knock you hear until the oil thins up more.
