2000 Cadillac DTS OIL PRESSURE SWITCH
2000 CADILLAC DEVILLE DTS
91,000 MILES • V8 • 2WD • AUTOMATIC
DARRICK BELLMAN
OIL PRESSURE SWITCH IS LEAKING AND WHEN I CRANK UP MY CAR IN THE MORNING THE ENGINE IS KNOCKING THEN IT STOPS AFTER 5 MINUTES. WHATS THE PROBLEM
May 9, 2010 at 12:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have you replaced the oil switch already ? leaky oil switch can cause oil pressure to leak resulting in the knock you hear until the oil thins up more.
May 9, 2010 at 12:55 PM
