pass key2 system only lets me start the car when it wants to
DGOLDBERG1221
I have a 93 cadillac deville touring 8 cylinder.it has 134000miles. my pass key two system only lets me start the on when the sun has not been on the car or it is not over 60 degrees out
Sep 25, 2007 at 10:46 AM
BUZZSAW
  • 1,198 POSTS
[quote:d122f6040e="dgoldberg1221"]I have a 93 cadillac deville touring 8 cylinder.it has 134000miles. my pass key two system only lets me start the on when the sun has not been on the car or it is not over 60 degrees out[/quote:d122f6040e]
need to start with a new lock cylinder, does it say wait 3 min across instrement panel or security lite blink?
Sep 26, 2007 at 11:56 AM
MEL LONO
  • 8 POSTS
I had a similar problem on my 1992 Deville. I bypassed the Vats system by inserting a loopback with the appropriate (resistance) ohms using about a dollars worth of resistors. You can find the fix by googling VATS Bypass. Also, make sure the key is clean. Use denatured alcohol. sounds silly, but this works.
Oct 16, 2007 at 9:15 AM
