1992 Cadillac Deville Transmission Delay
A02PADILLA
I have a 1992 Cadillac Sedan Deville, 143,000 miles on it. When I turn it on it the mourning it takes a while for the transmission to catch. And just yesterday when I was at a light and when it put on the gas the car just stopped while the engine was still on then I put gas to it then it jerked and took off. What could it be rather then morning sickness which could be an internal leak. Or does it need to be flushed out already?
Nov 3, 2007 at 1:48 AM
BUZZSAW
  • 1,198 POSTS
[quote:b1096a715c="a02padilla"]I have a 1992 Cadillac Sedan Deville, 143,000 miles on it. When I turn it on it the mourning it takes a while for the transmission to catch. And just yesterday when I was at a light and when it put on the gas the car just stopped while the engine was still on then I put gas to it then it jerked and took off. What could it be rather then morning sickness which could be an internal leak. Or does it need to be flushed out already?[/quote:b1096a715c]
the trans needs rebuilt or replaced, if you scan for codes a 39 code will appear, torque converter prob
Nov 7, 2007 at 4:06 AM
Suggested Repair
Have the transmission scanned for code 39. The expert attributes the delayed engagement and slip to a torque converter problem and recommends rebuilding or replacing the transmission.
Conversation Summary
The owner of a 1992 Cadillac Sedan DeVille with 143,000 miles reports slow transmission engagement after startup and a stop-light incident where the car stopped moving with the engine still running, then jerked and took off. The owner asks whether this is morning sickness from an internal leak or whether a flush is needed. The expert says the transmission needs to be rebuilt or replaced, that a scan should show code 39, and that the torque converter is the likely problem.
