2002 Cadillac Seville Flood Misfire
SHAIKH5622
My lil brother has a 2002 cadillac sevile it rained pretty hard here in houston he drove it into the water.. but not too bad it wasnt submerged.. however he was able to tow it back home. we've drained the oil. which is light Brown-Rusty color replaced the air filter. well the engine still turns over just sounds very bad . shakes alot , misfires , sort of sounds like a big pot of boiling water? what should i do? is there any hope left for this engine? i cant afford to take it to a mechanic or buy a new motor just trying the best we can
Oct 17, 2007 at 4:16 AM
BUZZSAW
  • 1,198 POSTS
[quote:4d2909683b="shaikh5622"]My lil brother has a 2002 cadillac sevile it rained pretty hard here in houston he drove it into the water.. but not too bad it wasnt submerged.. however he was able to tow it back home. we've drained the oil. which is light Brown-Rusty color replaced the air filter. well the engine still turns over just sounds very bad . shakes alot , misfires , sort of sounds like a big pot of boiling water? what should i do? is there any hope left for this engine? i cant afford to take it to a mechanic or buy a new motor just trying the best we can[/quote:4d2909683b]
water gets in the boots of the spark plug wires ck that first
Oct 29, 2007 at 3:51 AM
OMARSHAIKH90
HEY THANKS
MY MECH. SAID
THAT DA CRANKSHAFT HAD GONE BAD DUE TO
ME STARTING THE CAR OVER AND OVER
AND HE SAID DA WATER HAD DAMAGED IT
AND I NEED A NEW MOTOR OR TO REBUILD THE ENIGNE..
BUT JUST 2 MAKE SURE I WILL TELL HIM 2 OPEN UP THE COVERS N CHECK THE PLUGS FOR SPARK OR SOMETHING
Oct 29, 2007 at 3:57 AM
Suggested Repair
Check the spark plug wire boots for water intrusion first, since water there can cause misfires and rough running after driving through water. Do not assume the engine is ruined until that is checked.
Conversation Summary
A 2002 Cadillac Seville was driven through standing water, then towed home. The oil was drained and looked light brown and rusty, and the air filter was replaced, but the engine still cranked and ran poorly, shaking, misfiring, and making a boiling-water sound. The expert advised checking the spark plug wire boots for water first. The owner later said a mechanic blamed a damaged crankshaft from repeated starting and recommended a new or rebuilt engine, but planned to have the plug covers checked.
