Intermittent P041 "NO CAM REFERENCE" 95 DEVILLE
KEN MACLEOD
I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
What should I try next? There are no other codes.
Could the ECM be getting heat sensitive? Its a northstar with 78,000 miles. Otherwise very good condition.
The only other simptom I notice is that It will stall
at idle occassionally.
Would like to track this down. Thanks Ken
Nov 28, 2007 at 9:41 AM
BUZZSAW
  • 1,198 POSTS
[quote="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
Would like to track this down. Thanks Ken[/quo
what engine 4.6 or 4.9
Nov 29, 2007 at 11:54 PM
KEN MACLEOD
[quote="Buzzsaw"][quote:8c3c164b63="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
what engine 4.6 or 4.9[/quote:8c3c164b63]
4.6 northstar
Dec 9, 2007 at 4:39 AM
BUZZSAW
  • 1,198 POSTS
[quote="ken macleod"][quote:16a39b6451="Buzzsaw"][quote:16a39b6451="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
what engine 4.6 or 4.9[/quote:16a39b6451]
4.6 northstar[/quote:16a39b6451]
see if the wires to the sensor are loose when plugged in, sometimes there tight,when the engine flexes the wires get pulled on, when unpluged the ck to the ecm may show that there good( the harness isnt long enough )
Dec 10, 2007 at 4:35 AM
KEN MACLEOD
[quote="Buzzsaw"][quote:17c57480ea="ken macleod"][quote:17c57480ea="Buzzsaw"][quote:17c57480ea="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
what engine 4.6 or 4.9[/quote:17c57480ea]
4.6 northstar[/quote:17c57480ea]
see if the wires to the sensor are loose when plugged in, sometimes there tight,when the engine flexes the wires get pulled on, when unpluged the ck to the ecm may show that there good( the harness isnt long enough )[/quote:17c57480ea]
Have checked the wires out it dosent seem to be the problem. Have repalced the ECU (pricy) and it still happen excatly the same. it will stall once and a while at idle and sort of mis-a beat at highway speed and not stall. Now I am running into a low voltage situation. It seems to charge up enougth to start the car in warm weather but not cold.
Also it stalled on me 5 times, ONCE, on the way home from work. Always at idle. Noticed a P025 (x25 map : Crank sensor issue). Never did this again. This was the day after a 700 mile trip.
This car appearS to be in good shape and it runs well other wise. It is unmolested not somuch as a new radio - HELP! Is it a ground some where.. the alternator? Does have a trailer light package installed.
This was a factory install but someone put an old fashend connector on it.
m really frustrated. Please help someone.
Feb 12, 2008 at 3:09 AM
BUZZSAW
  • 1,198 POSTS
[quote="ken macleod"][quote:b2559e66b7="Buzzsaw"][quote:b2559e66b7="ken macleod"][quote:b2559e66b7="Buzzsaw"][quote:b2559e66b7="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
what engine 4.6 or 4.9[/quote:b2559e66b7]
4.6 northstar[/quote:b2559e66b7]
see if the wires to the sensor are loose when plugged in, sometimes there tight,when the engine flexes the wires get pulled on, when unpluged the ck to the ecm may show that there good( the harness isnt long enough )[/quote:b2559e66b7]
m really frustrated. Please help someone.[/quote:b2559e66b7]
if you had a crank sensor code replace them both, a relearn will have to be done through the dealer for crank sensors, it also sounds like the battery is no good also, but get your sys ck, what does it say it charging through the IP? 13.9 to 14.1 normal
Feb 15, 2008 at 8:29 AM
JIM277
[quote="Buzzsaw"][quote:5ed5b4409b="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
what engine 4.6 or 4.9[/quote:5ed5b4409b]
change the module in the distributor, I had the same problem on a 1992 deville, also have a dealer (one who knows the car) check the ICM (Idle control motor, and TPS throttle position switch)
this should take care of the stalling
May 19, 2008 at 4:11 AM
BUZZSAW
  • 1,198 POSTS
[quote="jim277"][quote:0d345e938f="Buzzsaw"][quote:0d345e938f="ken macleod"]I get a P041 engine code Intermittently. I will start happening once the engine warms up and then increase in frequency. I have had the sensor replaced and the connection to the ECM checked by my local machanic, and it still happens.
what engine 4.6 or 4.9[/quote:0d345e938f]
this should take care of the stalling[/quote:0d345e938f]
a 92 and 95 are totally diffrent motors, 95's dont have a distributor
May 21, 2008 at 11:03 AM
