How to remove water pump from a 97 cadillac deville northstar
SGRCOOKIESHELL
I need to know how to remove the water pump from a cadillac diville northstar?
Aug 25, 2007 at 12:13 PM
SEEK2CHASE
On the 4.6 Northstar motor the water pump is located on the driver's side. The process is pretty straight forward, but you must buy the special tool. This is like a large huge socket with notched teeth that grab the "ears" of the pump. I was able to buy the tool at local auto parts store for around $20+. Here is how the job is done in the images below.
Sep 26, 2007 at 4:02 PM
BUZZSAW
  • 1,198 POSTS
[quote:1746ce3a9f="Seek2chase"]On the 4.6 Northstar motro the water pump is located on the driver's side. The process is pretty straight forward, but you must buy the special tool. This is like a large huge socket with notched teeth that grab the "ears" of the pump. I was able to buy the tool at local auto parts store for around $20+.
Good time to replace small cam belt and hoses while everything is torn apart.[/quote:1746ce3a9f]
also if it is only seaping its a normal condition
Sep 30, 2007 at 9:02 PM
