where is the freeze plug on the block of a 90 cadillac deville. cant figure out how to get to it :(
Oct 13, 2007 at 3:22 AM
MERLIN2021
✓Experienced Mechanic
There are a few of them...what engine size? There will be some on the sides of the block, and on the rear....smaller ones on the cylinder heads...
Oct 13, 2007 at 3:32 AM
MIBUTTERFLYWINGS
MEMBER
[quote:8e423c6834="merlin2021"]There are a few of them...what engine size? There will be some on the sides of the block, and on the rear....smaller ones on the cylinder heads...[/quote:8e423c6834]
Its a 4.5 v8 , leak coming from front of motor on passenger side
Oct 13, 2007 at 3:40 AM
MERLIN2021
If you can get a pressure tester, this will help find the leak, and the coolant can be cold, here is the proceedure for water pump replacement...
