Deviile 2000 DTS
ROYALET
Hey guys I have a 2000 DTS, was running good till the other day, service check engine light came on, the next day the vehicle started to shake at the light (like a misfire) and it studders when I pull off. I was able to take it to the autozone where it was a P0202 code-fuel injector #2 open circuit, can anyone explain this to me? and second my check coolant light comes on, but the coolant doesnt appear to be low, the temp guage will move from the middile just a tad bit when driving, but it goes right back to the center? Thank you
Sep 12, 2007 at 3:32 AM
BRUCE HUNT
  • 3,754 POSTS
If the ignition switch shuts itself down or turns physically and goes to the off position, you need to replace the ignition switch.
Sunroof sounds motor or tracking related. But it could be the switch.
Oct 19, 2006 at 9:31 AM
LOIJAH
[quote:c096ce859b="royalet"]Hey guys I have a 2000 DTS, was running good till the other day, service check engine light came on, the next day the vehicle started to shake at the light (like a misfire) and it studders when I pull off. I was able to take it to the autozone where it was a P0202 code-fuel injector #2 open circuit, can anyone explain this to me? and second my check coolant light comes on, but the coolant doesnt appear to be low, the temp guage will move from the middile just a tad bit when driving, but it goes right back to the center? Thank you[/quote:c096ce859b]
Sep 15, 2007 at 3:29 PM
BUZZSAW
  • 1,198 POSTS
[quote:a5da7594a9="royalet"]Hey guys I have a 2000 DTS, was running good till the other day, service check engine light came on, the next day the vehicle started to shake at the light (like a misfire) and it studders when I pull off. I was able to take it to the autozone where it was a P0202 code-fuel injector #2 open circuit, can anyone explain this to me? and second my check coolant light comes on, but the coolant doesnt appear to be low, the temp guage will move from the middile just a tad bit when driving, but it goes right back to the center? Thank you[/quote:a5da7594a9]
should also give miss-fire codes, injector #2 bad, coolant resivor has a sensor in it, its either lo or sensor no good
Sep 17, 2007 at 6:52 AM
