1998 Cadillac Deville Coolant Loss
ROBERTH
My 1998 Cadillac Sedan Deville 195,000 4.6 Northstar engine is in the shop for the 4th time with this-It's going through coolant, I have to add it every other week or two. Now they say that the bolts on the head gaskets are loose because the theads have worn away and it is going through the exhaust system and that the only way to fix it is a new engine! It seems extreme for a coolant leak? I need another idea- I just don't believe my dealership.
Thanks for your help!
RCH
Feb 20, 2007 at 8:25 AM
2CARPRO JACK
  • 11,533 POSTS
Has any real work been done? ie: water pump , radiator ..... etc?
The water pump in your Northstar is at the rear of the engine, driven by the camshaft, rear being the drivers side
Aug 18, 2019 at 3:05 AM
ROBERTH
Yes, the water pump is not that old, the manifold was replaced first then they said it was the gasket at the thermostat that was leaking which should have been caught when they put the new manifold on but wasn't. They say that the threads to the bolts of the head gasket are stripped and that is where the coolant is leaking into the exhaust system. They say those bolts cannot be tightened or replaced the entire engine would have to be replaced. Is this true?
ROBERTH
They have also done pressure tests that say everything is working correctly.
CHEVY22
  • 1,375 POSTS
i see this almost every day , you do not have to replace the negine for the stripped (block threads ) it does need to come out and have time certs put in , that is where a jig is set on the deck of the block and all old head bolt block threads are drilled and replaced with time certs , no big deal on that part , but the negine needs to come down and heads removed and tell you the truth if you go that far have the case halfs selaed , lower oil pan gasket replaced and the rear main seal while its apart
ROBERTH
I think I understand what you are saying-but I am not familiar with "time certs" the engine has almost 140,000 miles on it-would I be better off to replace the engine with a new factory engine or try to go this route? Thank you for all your help.
CHEVY22
  • 1,375 POSTS
if the block threads have failed , you wil not see coolant on the ground , as far as replacement , if you plan on keeping the vehicle and can spare the change i would say yes go with a gm reman , it does have some miles on it and you may or may not have more problems in the future
Suggested Repair
Stripped Northstar head-bolt threads do not require a new engine. Remove the engine and heads, then install Time-Serts in the block threads. While apart, reseal the case halves and replace the lower oil pan gasket and rear main seal. A GM remanufactured engine is a reasonable alternative if the car will be kept and the budget allows.
Conversation Summary
A 1998 Cadillac Deville with a 4.6L Northstar was losing coolant and needing frequent top-offs. After water-pump, manifold, and thermostat-gasket work and pressure tests, the shop said stripped head-bolt threads were letting coolant enter the exhaust and that only a new engine would fix it. An expert said the engine must come out and the heads be removed so Time-Serts can restore the block threads, and recommended resealing the case halves and replacing the lower oil pan gasket and rear main seal while it is apart. A GM remanufactured engine was also suggested if the owner plans to keep the vehicle.
