Cadillac Deville wont start
BIGD1032RUNNER
Engine Mechanical problem
Cadillac Deville V8 Two Wheel Drive Automatic 119000 miles
the car turns over fine but wont fire almost like it dosent have any compression or it isnt getting fuel i backfired once.
Mar 17, 2008 at 3:28 AM
BUZZSAW
  • 1,198 POSTS
[quote:7454a927e0="bigd1032runner"]Engine Mechanical problem
the car turns over fine but wont fire almost like it dosent have any compression or it isnt getting fuel i backfired once.[/quote:7454a927e0]
what year is your Deville?
try squirting carb cleaner down the throttle plates or plate, while someone else turns it over, if it starts its fuel. start there
Mar 17, 2008 at 4:56 AM
BUZZSAW
  • 1,198 POSTS
[quote:2677b6293d="bigd1032runner"]Engine Mechanical problem
the car turns over fine but wont fire almost like it dosent have any compression or it isnt getting fuel i backfired once.[/quote:2677b6293d]
ok your going to have to pull the codes, push off and warmer on your milage center/heater controls, with the key in the on position. look in the milage center for the codes. starts out 8.8.8 and ends with 0.7.0, write them down and post them here
Mar 18, 2008 at 5:13 AM
BIGD1032RUNNER
the code i seen was E52
Mar 18, 2008 at 7:52 AM
